This message displays the contents of a transmitted or received MKPDU's SAK Use Parameter Set Body Each MKA PDUs (MKPDU) contains a sequence of "parameter sets": Basic, Live Peer List, Potential Peer List, SAK Use, Distributed SAK. The SAK Use Parameter Set Body is present after the Key Server elects to use MACsec and distributes the first SAK. LKSMI: Latest Key Server Member Id LKN: Latest Key Number LLPN: Latest Lowest Acceptable Packet Number OKSMI: Old Key Server Member Id OKN: Old Key Number OLPN: Old Lowest Acceptable Packet Number Further details on MKA parameter sets and parameters can be found in Clause 11.11 EAPOL-MKA of IEEE Std 802.1X-2010.
No action required - Informational message only.
Debug-Verbose
%direction% MKPDU on port %slotPort% [SAK Use] LKSMI:%lsrv_mi% LKN:%lkn% LLPN:%llpn% OKSMI:%osrv_mi% OKN:%okn% OLPN:%olpn%
| Name | Type |
| slotPort | SlotPort |
| direction | String |
| lsrv_mi | HexNosByteArray |
| lkn | uInt |
| llpn | uInt |
| osrv_mi | HexNosByteArray |
| okn | uInt |
| olpn | uInt |
